Evaluating metadata to connection paths
AA5MC
Post by AA5MC »
I have metadata that has a file path, now without scripting is there a way to compare the metadata to a outgoing folder?
For example:
In the metadata I have D:\myprinter1
and I have two out going connection to folders: myprinter1 and myprinter2
What I like to do ( again without scripting ) is the be able evaluate the metadata and route the file to the proper printer.
I know I can script this very easily however, I like to know if there is a way to decide what connection route to used base on the metadata.
thank you
Mike
Re: Evaluating metadata to connection paths
Right click on the connection and select "Include these jobs" and use Metadata.
https://www.enfocus.com/manuals/UserGui ... lters.html
AA5MC
Post by AA5MC »
Thank you for the replay.
We uses these function all the time.
What I was asking : Within the variables set is there a built-in variable that gives you the path (Preferable) or folder name of the out going connection .
if my out going connection is D:\temp for example is there a variable that will give me that information?
thank you for your help.
Mike
You can place anything you want in private data, so when routing a job you can make sure that different folders define the same private data key with different values.
