Extracting the delivery path from metadata
BeCa
Post by BeCa »
Is it possible to use a variable path in an output folder? And that the path is taken from the metadata?
In other words, I have a flow that the output folder should change depending the file. Since I do not want to have a flow for each file, nor have a common folder where files are dropped in, is it possible that the path of delivery is changeable?
The path I would like to use for each file is included in the metadata of the file, is there a way I can extract that and use it as a delivery folder?
Sorry if I'm not using the right expressions, I'm quite new in the Switch world.
Thanks!!
Re: Extracting the delivery path from metadata
You can do that with the "Set hierarchy path and Archive hierarchy
BeCa
Post by BeCa »
Thank you for the answer...
I'm getting this error now:
Flow error.jpg (8.71 KiB) Viewed 11006 times
What type of license do I need to use this feature?
I currently have the "Switch Core Engine" license only. If that is not included on my license, is there any other way of doing this?
Thanks!
BeCa
Post by BeCa »
Hi
Just wanted to know if you please have any information to help with issue.
Thank you for your help!
