Extracting the delivery path from metadata
Posted: Thu Oct 19, 2023 5:07 pm
by BeCa
Is it possible to use a variable path in an output folder? And that the path is taken from the metadata?
In other words, I have a flow that the output folder should change depending the file. Since I do not want to have a flow for each file, nor have a common folder where files are dropped in, is it possible that the path of delivery is changeable?
The path I would like to use for each file is included in the metadata of the file, is there a way I can extract that and use it as a delivery folder?
Sorry if I'm not using the right expressions, I'm quite new in the Switch world.
Thanks!!
Re: Extracting the delivery path from metadata
Posted: Thu Oct 19, 2023 5:19 pm
by jan_suhr
You can do that with the "Set hierarchy path and Archive hierarchy
Posted: Fri Oct 20, 2023 1:33 pm
by BeCa
Thank you for the answer...
I'm getting this error now:
Flow error.jpg (8.71 KiB) Viewed 11014 times
What type of license do I need to use this feature?
I currently have the "Switch Core Engine" license only. If that is not included on my license, is there any other way of doing this?
Thanks!
Posted: Thu Oct 26, 2023 5:00 pm
by BeCa
Hi
Just wanted to know if you please have any information to help with issue.
Thank you for your help!
