cliping mask
Urraco
cliping mask
Post by Urraco »
is there any solution to do this action?
1. select spot color Varnish
2. assign spot color Varnish to layer abc
3. add a rectangle to layer abc but smaller than trimbox whit 1mm width and 1mm height
4. make clipping mask only the layer abc
Thank you
Re: cliping mask
You can try this but would you mind explaining why do you need those steps? Especially the clipping part? Is it because you get Varnish out of the trim that you want to "remove"?
Let me know,
Loic
clipping_Varnish.zip
(2.24 KiB) Downloaded 1054 times
Urraco
Re: cliping mask
Post by Urraco »
Thank you very much for the action!
I do this because when cutting the paper, if varnish exceeds the cutting edge and is too thick, it cracks, peels off...
that's why I have to clip the varnish separation smaller than the trimbox, to avoid this problem
loicaigon wrote: Mon Dec 11, 2023 9:29 pm Hi,
Let me know,
Loic
