Transpile issue
Mongoose
Transpile issue
Post by Mongoose »
Hi all
Trying to understand and learn node.js. While trying to create a script using typescript I am having an issue with the transpile command in the terminal - it is giving me this error. What am I doing wrong? Any help much appreciated.
PS C:\Users\switch\Scripts\Node.js\Test> SwitchScriptTool --transpile .
SwitchScriptTool : The term 'SwitchScriptTool' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling
of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ SwitchScriptTool --transpile .
+ CategoryInfo : ObjectNotFound: (SwitchScriptTool:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Re: Transpile issue
It can't find it in the PATH variable.
You can write the full path to the SwitchScriptTool at the command or add the path to the PATH variable
Mongoose
Re: Transpile issue
Post by Mongoose »
Thanks Jan
It has returned this information which is fine
Usage:
SwitchScriptTool --pack <PathToFolderToPack> <PathToResultFolder> [--password <Password>] [--verbose]
SwitchScriptTool --unpack <PathToSscriptToUnpack> <PathToResultFolder> [--password <Password>]
SwitchScriptTool --create <ScriptID> <PathToResultFolder> [--JavaScript]
The script ID may contain only letters (A-Z, a-z), digits, hyphens and underscores
SwitchScriptTool --generate-translations <PathToScriptFolder> <PathToResultFolder>
SwitchScriptTool --transpile <PathToScriptFolder>
SwitchScriptTool --list <PathToSscript>
When I then follow up with
C:\Users\switch\Desktop\SwitchFolder\Scripts\Folder>SwitchScriptTool --create StringSplitter .
I get this return message
'SwitchScriptTool' is not recognized as an internal or external command,
operable program or batch file.
I have tried a few ideas from the web but no joy. Would you have any idea what this issue is?
Mongoose
Re: Transpile issue
Post by Mongoose »
Hi
For anyone else that may have this issue was able to fix by editing the environment variables and adding the appropriate file path there.
Re: Transpile issue
Have you tried it with this path:
C:\Program Files\Enfocus\Enfocus Switch\SwitchScriptTool\SwitchScriptTool --create StringSplitter "C:\Users\switch\Desktop\SwitchFolder\Scripts\Folder"
This should create a folder StringSplitter in C:\Users\switch\Desktop\SwitchFolder\Scripts\Folder and all the files you need to create the script.
