Is there a way to force Switch to process files based on the file name?
Offirest1977
Post by Offirest1977 »
Is there a way to force Switch to process files based on the file name? For example, I have 5 XML documents 123-1, 123-2, 123-3, 123-4 and 123-5 that need to be processed by a configurator in numerical order. Currently my flow is processing them randomly.
Re: Is there a way to force Switch to process files based on the file name?
In Folder apps bundle there is an app "File Sorter and Spacer". What you can do is first assemble all the XMLs that have to be processed into a folder and then using the app you can send them out in a specific order one by one with an interval.
