I have a flow where I would like to inject a file type pdf into a job folde thats running in the flow.
Is this possible? I have tried inject job inject lite but having no success.
Inject file into job folder
Re: Inject file into job folder
I ended up injecting the static file once the job was assembled. I then had to reassemble the job after the new job was injected. Isn't the cleanest solution but achieves what I needed to do without a script.
If someone has a cleaner solution would love to hear it. I tried to use the execute command and just copying the file into the temp folder but couldn't get it to work.
Hello!
I was wondering if you could post a sample of your flow?
I think I am trying to solve the same problem and I’m hitting a wall.
Any help is appreciated.
Thanks,
Jeff
Thanks,
Jeff
- magnussandstrom
Hi Jeff, maybe you can describe in detail what you are trying to do? There are many different scenarios, a 'generic flow with inject job' will probably not help you much.
