Rename Job replacing forward slashes with underscores
AndrewFriedman
Post by AndrewFriedman »
I noticed that whenever I send my jobs through the rename job element it will turn my forward slashes into underscores. In my sample value box, it has forward slashes but when I run the flow it will turn them into underscores. I'm assuming that there is some setting that changes special characters that Switch doesn't like into underscores. Is there a way that I can change this?
Thank you
Re: Rename Job replacing forward slashes with underscores
Each element in a flow is a folder in the Switch folders in which the job passes.
That's why you can't use a forward slash as the name for an element since that will men that you split the name of that folder in to two folders
