Is there a way to adding the folder name as a prefix to a filename.
For Example
Folder is called 123456
File is called TestABC
When Processed the file is called 123456 TestABC
Adding the Orginal Folder Name as a Prefix to a Filename
- magnussandstrom
Re: Adding the Orginal Folder Name as a Prefix to a Filename
What do you input to switch, only files or a job folders containing files?
It will be a folder very time containing files that goes into a hot folder or a submit point. The folder has a Job Number on it, if possible teh Job Number from the file needs to be added to the begining of the file name.
In the early part of the flow you set a Private data key that has the value of the job number you get from the folder.
Later in the flow you have a Rename element that adds that Private data key value to the filename.
