Select Spot Color Name & Use Name Value
GSBSwitch1
Post by GSBSwitch1 »
I am looking to select the name of any spot colors in an incoming PDF, and then use that name to write into a text line in the slug outside the live area of the PDF.
For instance if a spot color was named, "PMS 7056", I would select that copy, and then add a text string in the bottom slug of the art that said "PMS 7056".
Anybody know of a way to do this?
Re: Select Spot Color Name & Use Name Value
Aren't you simply looking at "Add Separations name"?
https://www.enfocus.com/manuals/Extra/A ... names.html
GSBSwitch1
Brilliant. Wasn't privy to this action. Thanks so much!
