Is it possible to sort images (portrait and landscape) and put them in two different folders?
square images should go to the portrait flow.
Sort images (portrait-landscape)
- JimmyHartington
Re: Sort images (portrait-landscape)
I would use a Switch calculation. Divide pixel-height with pixel-width and then use a connection to sort on this value larger than or equal to 1.
Then all portraits will end in one folder and landscape in the other.
If you need an example I will be happy to make one.
Switch calculation is not necessary. In the condition on a connection define [Image.ImageLength] greater than or equal to [Image.ImageWidth] for portrait and square, and the other connection takes all other jobs.
You can do it even simpler.
You have the variables for ImageLength and ImageWisth in the Image group
On the out going connection you set a condition with [Image.ImageLength] Less than [Image.ImageWidth]
the other connection gets "All other jobs"
- JimmyHartington
I love this forum. I am also learning something from such a relative simple questions.
Thanks to Jan and Freddy for the excellent answers.
I just recently changed how I do it since I needed other info as well, I used to do it how jan mentioned, now I use Pitstop Fastlane app to get the orientation as landscape or portrait and some of the other info I needed such as media/trim/bleed box and any Spot colors used.
I love how there are so many way to do things, and I agree these communities are great!!!
