I'm having an error message that says "No out going connection accepts this job"
geometry dash scratch
I'm also having a submit error, when files are being submitted through a hot folder on a different work station they are going directly into a quarantine folder without even going through the flow. The flow use to work fine but recently files are being lost in the system some how. I'm trying to find where the error is occurring but like I mentioned I'm no expert at enfocus.
Any help would be appreciated!
Enfocus Switch 12 Issues
- JimmyHartington
Re: Enfocus Switch 12 Issues
Look at the error e-mail and see from which folder it fails.
See if any of the connections from this folder has any parameters.
See this video: https://d.pr/v/S0M3uX
It is a good idea to also label the connections, so you visually can see what it does.
