Using one object as reference for the position of another?
Soul Forge
Post by Soul Forge »
Hello!
I'm trying to create objects based on the position of another objects.
Two things I'm trying to achieve are:
  • Create a text 4mm above a barcode
  • Create a text 4mm above another text I selected using REGEX
Do you guys know a way of doing this using only pitstop?
I was able to solve the barcode problem using switch, but it's not pratical since the file needs to go through Pitstop Server multiple times.
JimmyHartington
Re: Using one object as reference for the position of another?
Post by JimmyHartington »
I would select the object you need to reference. Set the Art box to selection.
And the place your graphic relative to the Art box.
