Archive Hierarchy UNC link error
Johnathan T
Post by Johnathan T »
We are trying to process files in a Network Drive, we have Submit Hierarchy pulling the files just fine using a UNC link, but when we try to put the same link in the Archive Hierarchy to put the files back it gives us an error and inverts all of the \ . We are new to switch and learning as we go but this has us stumped. Any help is appreciated. Thanks
r.zegwaard
Re: Archive Hierarchy UNC link error
Post by r.zegwaard »
You should use forward slashes, even while Windows uses bask slash.
So: //myshare/some/path is okay to use in Switch. Switch will translate it in the background
Johnathan T
r.zegwaard wrote: Tue Jul 30, 2024 7:05 am You should use forward slashes, even while Windows uses bask slash.
Thanks for the tip, unfortunately it makes no difference. It is automatically doing this on its own, and I get the error "the values of the following properties are not valid: path." While the error is pretty clear, it is also vague. What is wrong with the path? I am using the same on for the submit hierarchy and it has no issues. It also gives the same error if I give it the explorer path (Z:/)
If it is a shared volume from another server you must use the server name or ip-number instead.
Like //192.168.0.1/volume/folder
