Root directory of app
Meik
Post by Meik »
I've created a new node.js-app. In that app I'm using jsx-scripts that are located inside of the script-folder. The paths to the jsx-scripts are set to fixed paths inside of the TypeScript-code. I want to keep them dynamic though. How can I get to that root-directory in my TypeScript-code?
Using
const scriptFolder = __dirname;
gives me the temporary script executor path ("/Applications/Enfocus/Enfocus Switch/ScriptExecutor/libs") which is of course not usable for my case since I need the original directory of the main.ts
laurentd
Re: Root directory of app
Post by laurentd »
You can add Extra files in your app, using SwitchScripter.
Then use getPluginResourcesPath() to get the path to that folder.
Meik
Post by Meik »
thanks, works perfectly with the getPluginResourcesPath() function!
