email
kmcrae
email
Post by kmcrae »
HI,
how to remove the message in email;
"Email was triggered by this folder :"
thank!
email
What settings are you using? Have you tried using your own template instead of the built-in one?
kmcrae
email
Post by kmcrae »
built-in one!
email
Post by gabrielp »
It definitely goes away when you use an external file with the type set to HTML.
email
Note that inside the HTML mail template you can use any Switch variable [Job.Name], [Metadata...], etc. It is just that you will have to copy&paste it from the variables pane into the editor with which you make the HTML.
