Getting error message but no details on flow
matthew.hearne
Post by matthew.hearne »
Looking in the Messages panel in Switch, there are a load of errors being thrown saying "failed to load JSON dataset from file 'path to json file here': illegal value.
But there is no flow, job or element in the details for these.
How can I find out what is throwing these errors?
Thanks,
Matt
mkayyyy
Re: Getting error message but no details on flow
Post by mkayyyy »
It'll be tricky to find what's logging these errors, but from the error do you have any scripts or script expressions that might be trying to load datasets with a placeholder value of "path to json file here"?
tdeschampsBluewest
Post by tdeschampsBluewest »
It can happen if in the jobs panel of switch, you added a custom column (right click + show columns), with an improper value set (a script for example)
Note that custom value in such field are calculated each time you select a folder within switch designer, which could result in long calculating time.
