Switch alternatives
FrankT
Switch alternatives
Post by FrankT »
My maintenance contact for Switch is about to expire and I have been tasked with possibly using a different vendor. Switch is really good with automating tasks for me, integrating PowerShell and command-line commands.
But I have to show my boss alternatives.
Does anyone know of other applications that functions like Switch using GUI and low-code.
Thanks in advance!
mkayyyy
Re: Switch alternatives
Post by mkayyyy »
n8n is one that I've used in my spare time which if you self host it the functionality can be similar to Switch.
You can use it without the service contract but it can be limited in some ways.
tdeschampsBluewest
Post by tdeschampsBluewest »
To complet Jan message, without service contract you won't be able to get update, nor app (even the free one), but your flow will still works.
If you are late in your maintenance contract, you can still catchup later for a few years, but at some point it will be more expansive to catchup than buying a new licence.
The best advice i can give you is to contact your local reseller and talk with him about this, and consequence
I also use n8n that may overlap some functionality of switch, but it's nowhere near switch in term of integration for graphic art industry.
estaub
Post by estaub »
Dalim Twist
Esko Automation Engine
