Instability problem on M2 processor
cobra34
Post by cobra34 »
Hello everyone
I want to migrate my switch server to a new machine (Macstudio M2). So I downloaded the "Switch 2024Spring - Apple Silicon" version. But I encounter huge stability problems, after a few hours, the files are no longer scanned, my "Switch Service" process remains blocked at more than 100%.
The only solution is to kill the process so that the server continues to work (but this causes me loops on the unique prefixes of the file names).
Have you ever encountered this problem?
Thank you :D
Re: Instability problem on M2 processor
This is typically something that you should also report to support: https://enfocus-community.force.com/customers/s/cases.
I am personally not aware of any such problems. I am using an M3, though. Could it be related to the version of the OS? Support for MacOS 15 was added to the Fall release that was made available yesterday.
cobra34
Post by cobra34 »
I upgraded to the new version and the bug is resolved. But I had to delete my entire "switch server" folder which is in application support to regain stability
