Hi Guys!
Just wondering if anyone has come up with a way (or could think of a way) to reorder a CSV based on something super simple such as column X descending.
Basically, the data is "grouped" in such a way that would make it far easier for our fulfillment guys if it was in order (think data tagged in column X with a gets pack a, b gets pack b, etc. but the data is sorted by column Y by default).
Any help much appreciated - thanks in advance!!
Sorting a CSV before processing?
- magnussandstrom
Re: Sorting a CSV before processing?
Yes, get Easy Data Transform: https://www.easydatatransform.com/
And there is a new Switch app that makes it super simple to run the "transforms" in a Switch flow: https://www.enfocus.com/en/appstore/pro ... sform-beta
Last edited by magnussandstrom on Wed Nov 13, 2024 12:26 pm, edited 1 time in total.
- JimmyHartington
Magnus beat me to it.
I second the suggestion for using Easy Data Transform.
This looks absolutely perfect - I will have a play!
Thank you both!!
Thank you both!!
- tdeschampsBluewest
Oh the scam... Bot are getting creative this days. (i removed the scam part from the double link, to avoid people clicking it...)dramaticinsecure wrote: ↑Wed Nov 20, 2024 8:18 amIt uses a visual workflow approach, allowing users to drag and drop transformations for CSV, Excel, and text files without coding.magnussandstrom wrote: ↑Wed Nov 13, 2024 12:23 pm Yes, get Easy Data Transform: https://www.easydatatransform.com/
What do you mean scam part? The weird geometry dash bit at the end?
Yes, i did not even clicked on it, but when you see a new user with only 1 post, quoting and adding something to a link... well...
It's either a scam, or something to boost click/view/cross references...
Same link is also in the bio of the last user posting here :
viewtopic.php?t=4542
Huh yeah you're right - what a weirdly specific place to be adding spam links to things!!
