Switch Admin Dashboard issue
netaware
Post by netaware »
I have recently migrated my Switch server and I am having difficulties with getting to the Admin Dashboard Website.
Initially the port, 51089, needed to be opened by my network group.
Now when i attempt to view it, I cannot get to login because i get a message "connection to server is lost" and a reconnect bottom.
Does anyone have any ideas? Is there another port that needs to be open or some other setting?
Thank you for your help.
Re: Switch Admin Dashboard issue
You need to open port 51088 too
netaware
Post by netaware »
Thanks! i will give that a try.
netaware
Post by netaware »
Opening the additional port solved the problem.
Thank you very much for your help
