Tip: Document flow
JimmyHartington
Tip: Document flow
Post by JimmyHartington »
This tip took me far too long to find.
I have known about the "Document Flow" options from the Flow menu for a long time.
In some of my more complicated flows, I set a lot of metadata on a folder, as seen in the screenshot below. I then start and stop flows to find the private data key I need for other parts.
However, if you document the flow, you can simply go to the browser and copy-paste from the flow element there—a real time-saver! :)
magnussandstrom
Re: Tip: Document flow
Post by magnussandstrom »
Greate tip Jimmy!
I always color my folders with Cyan if I use them to set Private Data values, to also have a visual marker.
JimmyHartington
In my case orange is the color of folders with metadata.
Is metadata sounding like orange in Danish :)
JimmyHartington
Hi Loïc
No, just think it was the one color which looked most like the standard yellow.
I use some of the more different colors for other types of folders.
WilcoHordijk
Post by WilcoHordijk »
Thank you for this great tip. No more searching by clicking the elements to find the private data field you need!
