how to reset a scope of global data
ArielRauch
Post by ArielRauch »
I would like to "set to null" all tags defined under a specific scope.
Is this possible?
Ariel
The call to set global data requires strings, so when you are maintaining your global data you cannot set values to null. You will have to set an empty string and test for empty string when you are using global data. That is by the way also what getGlobalData returns when you are trying to get the value of non-exsiting global data.
ArielRauch
thanks, Freddy.
What I meant to ask was whether there is a way t o"reset" (set to "") all tags under a specific scope at once or iteratively without knowing the name of the tags.
Post by dkelly »
ArielRauch wrote: is a way t o"reset" (set to "") all tags under a specific scope at once or iteratively without knowing the name of the tags.
no
ArielRauch
I thought so:)
