Photoshop 20.0 app
ConquestUser
Photoshop 20.0 app
Post by ConquestUser »
When I try to use the photoshop app in switch it just stays at switch is completing task you requested but never goes any further. I have to restart the machine cause I can't even restart switch. I've remove the app and tried it again with same results. Any help would be appreciated. All this so I can have a hot folder to reduce images in size.
Re: Photoshop 20.0 app
Please report this to support: https://enfocus-community.force.com/customers/s/cases
Apart from this, if the only thing you want to do is to reduce the size of images (by reducing the resolution I assume) then a much faster, much more efficient alternative is to use ImageMagick. You can install that on your Switch server and run it via "Execute command". There is also an app that makes the whole setup a lot easier: https://www.enfocus.com/en/appstore/pro ... ick-helper
sander
Post by sander »
Once I had a likewise Photoshop issue too: it wouldn't start processing. After heavily testing I came to the conclusion there's different behaviour that depends on the way Switch is started. It might help you too:
OS: Windows Server 2019 + Adobe Photoshop 2024!
