trying to add hierarchy. For this, I try to extract "SA" from jobname
D_SA_1040.pdf
The used regex is
(?<=[a-zA-Z]{1}_)[a-zA-Z]{2}
It does not work. Is lookbehind supported by Switch?
Kind regards,
Jörg
regex: Lookbehind not supported?
Joerg Schober
Lookbehind is indeed not supported.
I assume you are using this regular expression in the Search field of the Job.NameProper variable. There Switch only matches the first occurrence, so [a-zA-z]{2} would also return SA.
Joerg Schober
Thanks Freddy for the reply.
There are also other filenames that are different (SE_MM_1804, ...), so the regex needed in production enviroment is
(?<=[a-zA-Z]{1,2}_)[a-zA-Z]{2}
How could i solve this issue. Is a script expression possible?
Supports javascript lookbehind (with variable length)?
It seems most languages only supports lookbehind (if they supports) with fixes length.
Kind regards,
Jörg
Kind regards,
Jörg
ArielRauch
If I understand correctly you want to extract the different segments of the name. Should not be a a problem in a script expression.
Nameproper.split("-")
Or did I misunderstand you
- TOP CONTRIBUTOR
Joerg Schober wrote: try to extract "SA" from jobname
D_SA_1040.pdf
A script expression to retrieve "SA" part would be:
job.getNameProper().split("_")[1];
D_SA_1040.pdf
