Simplified postprint separation
dinae
Post by dinae »
Hi.
I am an employee of who works for a book-making company in Korea.
Flow content.
A red box.
Hope for a way to reduce it to 1 line.
Switch version used: 2023
Use module : Core engine, metadata module
I am not good at English. Please understand
Attached is the flow, the action you use, and the example file.
https://drive.google.com/file/d/115vDhs ... drive_link
https://drive.google.com/file/d/1SjntVg ... drive_link
Re: Simplified postprint separation
First of all, we are probably not a lot capable of speaking korean, so don't apologize for your engligh ;)
Second of all, I understand that you are looking at creating 3 kind of outputs:
- The print content
- The Scodix separation
- The Foil separation.
Because PitStop Server can only output 1 pdf at a time, I don't think that you can achieve this with one line using PitStop Server alone.
What you could do to have something relative simple is use PitStop Server to put the different contents on different layers (ex: SCODIX on SCODIX layer) and use this app to generate the different output:
https://www0.enfocus.com/en/appstore/pr ... pdf-layers
Then you could rename file afterwards.
Unless someone can come with a smarter approach…
dinae
Post by dinae »
Thanks for your reply.
