Hi all
The "PitStop Workgroup Manager" folder in PitStop Pro seems randomly sorted. Is there a way to sort or rearrange action lists that are distributed through the Workgroup Manager, i.e. alphabetically?
Workgroup Manager - Sort Action lists
- tdeschampsBluewest
Re: Workgroup Manager - Sort Action lists
By default, I believe they are sorted by date of creation.
However, you can change the sorting behavior by clicking the magnifying glass icon in the search field.
This opens a menu where you can select the "Keep Sorted" option to apply alphabetical order.
That works, thank you!
Oh, I see. I thought it was alphabetical by default. Thanks for showing me how to change the sort!
Im a big fan of Space Waves
A follow-up question regarding the Workgroup Manager: Every one except two people in our company can see the "PitStop Workgroup Manager" group in the Action lists panel. We all use the same settings and are connected to the same PitStop license server. But two of us cannot see the group. The group in the manager is defined to include everyone and exclude no one with one folder providing a set of action lists. There are no forced settings. We have no specific users defined in the users panels. Any ideas why these two might not see them?
Could that be that the ports are taken over by some other processes for those users?
https://cdn-www.enfocus.com/manuals/Use ... esets.html
Enfocus PitStop Manager
That doesn't seem to be the problem. doesn't return anything. And if the port were the problem, would the two even be able to use PitStop at all? I thought the license was distributed through that IP and port combination as well. We're working with floating licenses.
sudo lsof -i -n -P | grep :50905
I would suggest to contact support then for further analysis.
Loic
Loic
