How to trigger conditional flow based on file metadata
Posted: Sun Jul 13, 2025 9:08 am
by sofaclean
Hi everyone,
I’m trying to set up a flow in Enfocus Switch that routes files based on custom metadata (like job name or client ID). I want the flow to evaluate this metadata and then direct the file to different folders accordingly.
Is there a recommended way to do this using variables or expressions within Switch?
Also, can I use metadata from an external source (like a CSV or XML) as part of the routing logic?
Appreciate any guidance or examples from those who’ve done similar setups
Re: How to trigger conditional flow based on file metadata
Posted: Sun Jul 13, 2025 3:31 pm
by jan_suhr
Have you tried to make two outgoing connections from one folder to two folders. Then right click on the connection and select "Include jobs/Define conditions with variables"
Then you can set up rules on what should go in that outgoing connection.
Posted: Mon Jul 14, 2025 10:00 am
That is Switch 101. I suggest you check the Learn section on our website: https://www.enfocus.com/en/learn/switch
