Set Bleed Box to .125" ONLY when objects bleed
dbarbee
Post by dbarbee »
We have a device with device with a harlequin rip that does not honor PDF page boxes. The rip will also print any objects outside of the page boxes such as crop marks even when they don't show. I am trying to create an automated workflow that requires no user intervention. The challenge is the final PDF needs to only have a bleed margin if an object bleeds. If nothing bleeds, the bleed box should equal the trim box. Is it possible to detect if an object crosses the trim box and then if true, set the trim box to .125" beyond the bleed box? Here is my action list so far:
Select all
Change media box to trim box size
Resize media box by (0.125 in, 0.125 in, 0.125 in, 0.125 in)
Move media box to 0.0
Change bleed box to media box size
Change art box to media box size
Change crop box to media box size
Re: Set Bleed Box to .125" ONLY when objects bleed
Select objects close to the page edge
Select page if content is selected
Change boxes
As for all actions, if nothing is selected then nothing happens.
dbarbee
Post by dbarbee »
Thank you, and I like where you're going. I'm not that familiar with Pitstop, and having trouble getting this to work properly right off the bat. My problem seems to be it's not detecting objects close to the bleed. I'm not sure why.
I'll fiddle around with it, and see if I can get it to work. Otherwise, I've attached my action list.
Set page geometry boxes.zip
(2.81 KiB) Downloaded 289 times
dbarbee
Post by dbarbee »
I figured out my problem. I did not have a sufficient distance past the trim line to identify objects that bleed. After adjusting to something huge (30 inches) it works like a champ. Thanks!
