How to remove Failure message
DJS
Post by DJS »
I have a PPP which rejects a PDF that has any type of protection added to a PDF. which runs perfectly.
I have a problem in that there is a check which happens before the PDF can report the error, which says "Not allowed to edit the page content."
Screenshot 2025-07-15 at 10.18.25.png (183.57 KiB) Viewed 28182 times
How do I disable the "Failure" message and let the PPP message be the response?
Thank you
kennethkreut
Re: How to remove Failure message
Post by kennethkreut »
I got the same issue. Did you find any solution?
DJS
Post by DJS »
No solution offered, have raised a ticket, which was closed and now reopened, was also recommended "going to My Enfocus/PitStop/Feature Requests and add your voice over there as well." the more there is on the issue the more likely it is to be solved - good luck!
Screenshot 2025-11-20 at 08.29.08.png (89.02 KiB) Viewed 14835 times
