Switch backup
ArielRauch
Switch backup
Post by ArielRauch »
What shall be backed up within a switch installation? Is it only the flows?
In addition I have heard about a "tandem" installation? What is that exactly.
Ariel
Switch backup
You should backup everything in the application data root folder, the path of which you can find in the Preferences.
It a commercially interesting solution in case you need two Switch environments for additional processing and/or fail-over. Note that it is not an automatic fail-over environment!
ArielRauch
Switch backup
Thank you - got it
