I have to deactivate the enhanced security because of the needed installation of Enfocus Pitstop 25.03 plugin. The problem is that is worked before but with the latest update of operation system sequoia 15.4.1 + update from acrobat.
Also I believe it is only with M3 or M3 max processors that we see it at other clients to.
Acrobat latest version and pitstop 25
koen_Degrande
Re: Acrobat latest version and pitstop 25
Hi Koen,
Are you saying that having the combo: sequoia 15.4.1 + update from acrobat.
You can't disable protected mode?
If so can you create a support case?
