I have some very strange behavior when trying to define a submit point and connect later on checkpoint. When I am selecting fields from the submit point (not all of them - only some) into the checkpoint and try to save the flow it does not save it but produce the error message:
Checkpoint backing folder path is empty; reactivate the flow
Any ideas?
Ariel
The field that makes the trouble is a dropdown field with script expression
Submit - Checkpoint problems
I have been able to reproduce your problem, I think. I do not get the same error message (but I am not using the same version you are), but there is something wrong with drop-down lists from a submit point used in a checkpoint.
I will log this.
I will log this.
Thank you.
I have already reported to the support and after a screen sharing session they approved the bug.
If someone needs a workaround let me know - I have some ideas
