I'm running what I thought would be a simple flow. I'm trying to get the pitstop server app to run an action that works in pitstop and pitstop server with the job name being the variable to create the barcode but it does not work in switch. Any thoughts.
Thanks,
Bruce
Micro QR code Switch Pitstop Server App
ConquestUser
- JimmyHartington
Re: Micro QR code Switch Pitstop Server App
Hi Bruce
I have made a short video how I setup getting a variable from Switch into a Pitstop Action in Pitstop Server. Hope this can help
My solution between Pitstop Pro on macOS and Switch with Pitstop Server on Windows has been to create a variable set database located on a shared network volume.
Then create the variable set and action list in Pitstop Pro.
Create a flow in Switch. Setup the Pitstop configurator to use the action list and shared variable set. Edit the variable set through the configurator in Switch and change the variable to use metadata from Switch.
I have made this short video (4 min.) which shows the process from creating a variable set and action list to execute it with metadata from Switch.
In this case it was just 3 private data keys set on a folder.
https://d.pr/v/HjFwMM
