We receive many pdf files where the Cut and Crease lines are in the artwork, however for our digital printers we need to separate the Die-Cut from the artwork.
In most cases I open the file in Illustrator and create a separate file with only the Die-cut, which goes on top of the artwork in Indesign.
Then I delete the Die-cuts in the original pdf.
Is it possible to create an action list where the Cut and Crease lines, so two spot colors, are moved to a new, blank page?
I have tried several actions, but these only move one of the spot colors. Suggestions?
Move Cut and Crease Lines to new page
Re: Move Cut and Crease Lines to new page
If you can get it to work on one spot color, can you just make another action that works for the other spot color? If so, then you could combine the 2 actions into. a QuickRun.
Split Action
Select spot color (choose to make a list of spot color names)
Copy/cut
Select all
Add pages
Select pages (last one)
Paste
@CruzinCooler: using "Split Action List" is not wrong, but not strictly necessary because the new page is added at the end and this means the Action List is still moving forward through the pages.
Copy/cut
Select all
Add pages
Paste
Hi all,
May I suggest that you have a look at the "Add pages with extracted content" Action?
While the title might not be that explicit, the point here was actually to separate print content from technical content:
https://www.youtube.com/watch?v=YK38tBrEYVI&t=9s
Before (blue mimicks gold here):
After:
So all you need is select your technical colors and add Action "Add pages with extracted content"
After:
Enfocus PitStop Manager
I stand corrected. Good point. Thank you freddypfreddyp wrote: ↑Thu Sep 18, 2025 12:06 pm Select spot color (choose to make a list of spot color names)
Copy/cut
Select all
Add pages
Paste
