Global Variable
jasonx
Global Variable
Post by jasonx »
Happy new year everyone.
I am trying to clean up my flows abit.
Whats the best way for having a global variable? For instance if I have Enfocus Griffin and I have 40 configurators in my flows I'd like to have a central place to specify the license key. So if that changes in the future I can change it one spot.
plutinolabs
Re: Global Variable
Post by plutinolabs »
Maybe you could use an app like Sublflow.
You could send all the jobs through a single sublflow that only contains a folder (or some other app) that would add the Griffin config as private data.
jasonx
Re: Global Variable
Post by jasonx »
thank you that seems like the cleanest solution.
magnussandstrom
Re: Global Variable
Post by magnussandstrom »
"Global Switch variables" is the one most requested feature on the Switch feature request page, and it recently got marked as planned. So I suppose this will be built into Switch in an upcoming release quite soon.
https://my2.enfocus.com/en/switch/featurerequests
plutinolabs
Re: Global Variable
jasonx wrote: Mon Jan 12, 2026 9:05 am thank you that seems like the cleanest solution.
Glad I could help
Re: Global Variable
With this app you can also do what you have in mind: https://www0.enfocus.com/en/appstore/pr ... lobal-data
