Assemble Job - Job identifier
Posted: Fri Jan 16, 2026 2:56 pm
by schmitzdp
I am trying to assemble several files with the ‘Assemble job’ application. I define the assembly according to an identifier that is private data. This same private data is also used to name the folder.
However, all the files pass through without being grouped.
Does this application support private data? Or have I forgotten something?
Thank you.
Re: Assemble Job - Job identifier
Posted: Fri Jan 16, 2026 3:33 pm
by magnussandstrom
What setup do you have on the following settings?
Number of files
After N minutes
Complete condition
Posted: Mon Jan 19, 2026 11:26 am
by schmitzdp
magnussandstrom wrote: ↑Fri Jan 16, 2026 3:33 pm
Number of files
After N minutes
Complete condition
Number of files : 0 (deactivated so ?)
After N minutes : 1
Complete condition : Nothing (deactivated so ?)
I want jobs to be grouped together by Job identifier after 1 minute.
Posted: Mon Jan 19, 2026 2:29 pm
by magnussandstrom
I don't think you can set Number of files to 0. If you instead set Number of files to 99999999, the After N minutes have higer priority and will trigger the Assemble.
Posted: Tue Jan 20, 2026 9:18 am
by schmitzdp
magnussandstrom wrote: ↑Mon Jan 19, 2026 2:29 pm
This resolves the job assembly issue. Thank you very much.
