Access Metadata within script
ArielRauch
Post by ArielRauch »
I have a jdf file which I added to an asset (JDF pickup) and now I would like to access Metadata via a script expression.
I am struggling with the syntax.
Can someone send me an example about how to access the xml(jdf) data?
Ariel
The easiest method is to use job.getVariableAsString("[Metadata.Text....]");
Build the metadata query first and then copy and paste it. Beware of escaping the double quotes!
ArielRauch
Wow, thanks - did not think of that way.
What about the other (probably more complicated way) via the metadata interface (getString())? Do you have any examples for it - (I know I should stop here - but my technical inside shouts for knowing the other possibility:))
var dataset = job.getDataset("Name of dataset, probably Jdf");
var metadata = new Document(dataset.getPath());
var namespaceMap = metadata.createDefaultMap();
var jobID = metadata.evalToString("/jdf:JDF/@JobID",namespaceMap);
s.log(1,jobID);
ArielRauch
thank you very much, Freddy.
I already implemented your first approach but I will probably change it to this solution.
Again thanks,
Ariel
