Compare in ImageMagick
_olq
Post by _olq »
Hi all,
Is there a possibility to use the tool 'compare' contained in the 'ImageMagick' through Switch tool 'Execute command'? I did some tests with the command line and it works well.
I don't know how to indicate two input files to be able perform the operation.
I would like to make it like this:
'Input folder (with files to compare)' -> compare -> output folder (with file comparison)
Thanks in advance,
Aleksander
Aleksander
Post by gabrielp »
_olq wrote: I don't know how to indicate two input files to be able perform the operation.
I don't know much about ImageMagick apart from using the PHP library. But if you figure out how to specify the input files in command line, you could probably define some temporary files (or static ones on your filesystem) using the File class. Once those temporary paths are tied to a variable, I imagine you could pass that into ImageMagick. Hope that helps
_olq
Post by _olq »
gabrielp wrote: you could probably define some temporary files (or static ones on your filesystem) using the File class. Once those temporary paths are tied to a variable, I imagine you could pass that into ImageMagick.
Hi Gabriel,
What you say makes sense, but I have no idea how to do it :)
Could you show an example?
Aleksander
Post by dkelly »
I wrote this configurator for Imagemagick's compare
https://www.dropbox.com/s/dihwpwv8d48ah ... cript?dl=0
Dwight Kelly
Apago, Inc.
_olq
Post by _olq »
I'm pleasantly surprised, it works great.
Good job Dwight, thank you very much!
Aleksander
_olq
Post by _olq »
Maybe just one little question :)
Where should I add options to compare command?
Aleksander
Post by dkelly »
Edit the script, find the lines that start with argv[argc++] and add or modify options.
_olq
Post by _olq »
Thanks again Dwight,
I have some trouble with that.
When I'm adding an option with the existing I have error "Failed to run external process"
args[argc++] = appPath+" -metric AE -fuzz 5%";
args[argc++] = job.getPath()+"/"+entries[0];
args[argc++] = job.getPath()+"/"+entries[1];
args[argc++] = differenceFN;
If I'm adding separate, option has no effect
args[argc++] = appPath;
args[argc++] = " -metric AE -fuzz 5%";
Do you have any idea?
Aleksander
Post by dkelly »
Follow the pattern that is already there for arguments
args[argc++] = "-metric"; args[argc++] = "AE";
args[argc++] = "-fuzz"; args[argc++] = "5%";
_olq
Post by _olq »
So, it was reason :)
Of course works correctly.
Big thanks again!
Aleksander
joaodaffonsojr
Re: Compare in ImageMagick
Post by joaodaffonsojr »
dkelly wrote: Mon Oct 13, 2014 3:00 pm I wrote this configurator for Imagemagick's compare
Dwight Kelly
Apago, Inc.
Hello Dwight! I know this is a little old, but I would really appreciate some help on this if possible.
I'm trying to run your script but it's giving an error:
Screenshot 2022-08-21 193006.png (4.41 KiB) Viewed 15993 times
João
