Ghostscript PDF to TIF
congomonster
Post by congomonster »
i need some help for a conversion from PDF to TIF. I have Ghostscript installed and it worked with the terminal. I think my problem has something to do with the output path.
Arguments: -q -dNOSAFER -dNOPAUSE -dBATCH -r300 -sDEVICE=tiffg4 -sPAPERSIZE=a4 -deletfile "%2" "%1"
Output: file in path
Extension: Tiff
And i turned the endcode of. Switch says the it come out with the code=1
I think i must put -OutputFile= in my code. But that doe's not work. Can anybody help please?
_olq
Post by _olq »
I think you forgot "-o" operator
See code below.
-q -dNOSAFER -dBATCH -dNOPAUSE -sDEVICE=tiffg4 -r300 -o "%2" "%1"
Aleksander
Yes, you must add an argument for the output file, but it is not -OutputFile, but -sOutputFile.
Apart from that, I advise to put the whole command in a shell script or BAT file. So, in "Command or path" you choose the script file, in "Arguments" you just put "%1" "%2" and in the shell script (in my case) you write:
#!/bin/bash
/usr/local/bin/gs -q -dNOSAFER -dNOPAUSE -dBATCH -r300 -sDEVICE=tiffg4 -sPAPERSIZE=a4 -sOutputFile="$2" "$1"
exit
Do not forget to chmod +x the shell script! On Windows it is similar, but in the BAT file you do not use $1 and $2 but %1 and %2.
congomonster
Awesome! it workss now! BIG Thank You!
