Pitstop server - select all that is not spot
ArielRauch
Post by ArielRauch »
how can I select everything that is not spot colored.
I thought it would be easy to select all by spot colors and then inverse the selection but I did not find a way to do it.
Any advice is more than welcome
Ariel
Inverting the spot color selection still gives you spot colors, so inverting all spot colors gives you no spot colors :)
You can select by color space. As spot colors are usually defined as "Separation" or as "DeviceN" you know that anything that is not in those color spaces is not a spot color. (I guess NChannel is theoretically also a possibility, but I have never yet seen such a file).
