Check what plate used for each page
nurhood
Post by nurhood »
Hi There,
I am wondering if it is possible to check plate used for each page. The only available action is 'Select by number of color plates'. From this action, I could only detect page having more than the amount set. Thank you.
In the General tab of the preflight profile you can activate the option to add "Inks" to the report. This will add the surface coverage of every ink on every page (inks with 0% coverage are not listed). This is in other words the best and safest method to conclude what separations are actually being used on what page.
nurhood
Post by nurhood »
Hi Freddyp,
Forgot about that! Thanks a lot Freddy!
