Asset path
abonsey
Asset path
Post by abonsey »
I have an XML pickup that is looking for an asset.
First of all I tried point at the asset path that contained XML data of the PDF name. This failed stating it failed to find the asset.
I then tried just entering a static path to the asset required. This resulted in the same error about the asset not being found.
If I use the path manually in an explorer window it all works OK.
The asset is stored in the same location as Hotfolders for Pitstop so I know the access privileges are OK.
Anybody seen anything like this. Any ideas?
Asset path
How did you configure this exactly? You have to set the XML pickup mode to "Metadata refers to asset". You then define the XPath to the file reference from the Metadata variable group. The reason you have to do it like this, is because the XML pickup will add the XML as a dataset to itself (like for "Metadata is asset") before searching the file reference in the metadata.
Works for me, both on Windows and OS X. If you do not have a complete path, you can build a combination of a fixed string pointing to the folder and a variable part for the file name.
abonsey
Asset path
Post by abonsey »
I did try that... with a combination of fixed path and the XML data ie metadata refers to asset, but it fails regardless of where I put the asset!
Asset path
What is your exact single-line text with variable and what is the line in the XML your XPath is referring to?
