Adding meta data to an existing database
kcratty
Post by kcratty »
II have a Connect App to be used to submit data to a workflow. When it is submitted, the user would enter information that would be a part of the metadata. I am looking for a script to add the metadata to the existing database on every record.'
Example:
meta data: Presorted
Data as submitted:
Name,Address,city,state,zip
John Doe, 123 doverLane, Lanham, MD, 20008
Jane Doe, 123 doverLane, Lanham, MD, 20008
After script
Name,Address,city,state,zip,Indicia,background
John Doe, 123 doverLane, Lanham, MD, 20008,presorted,imageA
Jane Doe, 123 doverLane, Lanham, MD, 20008,presorted,imageA
Is this possible with Javascript?
It is possible. It is easier with the Database Module because then you do not have to script anything. You can directly call the database with the "Database connect" element.
Post by dkelly »
You mention that the metadata from Connect will contain the presorted information. Where does the other data come from? Are you updating existing database records or insert new ones?
