Variable Data
GaryPrintnw
Variable Data
Does anybody know of a program that works with switch to run variable data on a piece. I will always have the same fields and the same master file, Just need to print variable data from an excel document on it
Variable Data
GaryPrintnw wrote: Does anybody know of a program that works with switch to run variable data on a piece. I will always have the same fields and the same master file, Just need to print variable data from an excel document on it
We use HP SmartStream to do exactly that. It's a plugin for InDesign.
GaryPrintnw
Variable Data
Im a bit confused on HP Smart Stream, Does the program allow you to create a pdf from the variable data or does it only directly print to HP Indigo presses?
Variable Data
GaryPrintnw wrote: Im a bit confused on HP Smart Stream, Does the program allow you to create a pdf from the variable data or does it only directly print to HP Indigo presses?
It makes PDFs/JLTs which can be sent into Indigos or elsewhere.
You would want to look into SmartStream Designer. Of which Switch has ready-made VDP configurators.
