Changing save options in Photoshop
aoswood
Post by aoswood »
I cannot get a file to save properly with PNG options in Photoshop CS6.
$outfile = new File($outfolder + '/' + $filename + ".png");
var pngSaveOptions = new PNGSaveOptions()
pngSaveOptions.compression=9 // (level of compression 0 .. 9 0 - without compression)
pngSaveOptions.interlaced=false
$doc.saveAs ($outfile, pngSaveOptions);
I get an extremely helpful error message from SWITCH:
"Script returned error: "
Re: Changing save options in Photoshop
You should put a try .. catch to display errors. The main problem, however, is that you did not return the path to the created file. The correct code looks like this:
var outfile = new File($outfolder + '/' + $filename + ".png");
var pngSaveOptions = new PNGSaveOptions();
pngSaveOptions.compression=9;    // (level of compression 0 .. 9 0 - without compression)
pngSaveOptions.interlaced=false;
try {
    $doc.saveAs (outfile, pngSaveOptions, true);
} catch (e) {
    $error = e;
//pass the output file back to Switch
$outfiles = new Array();
$outfiles.push(outfile.fsName);
Oh, and end your lines with a semi-colon.
aoswood
Post by aoswood »
I always forget those darn Semicolons. Thanks for you for the help worked perfectly. It also helped me out with another script that was broken.
