We have purchased a second license for Switch to use as a Developer Server, but as I'm setting it up and moving flows from the Production Server I got some error messages regarding PitStop Server elements.
Is it possible to somehow link the PitStop Server elements to the PitStop Server running on the Production Server or do I have to purchase a second license for PitStop Server as well?
							Switch Developer Server
Re: Switch Developer Server
Unfortunately Switch cannot connect to a PitStop Server (or any process) on a different machine.  Depending on your situation, you may be able to use one of several solutions:
						- * Use a dummy element instead of PitStop Server; perhaps a simple scripted element which fakes those parts of processing which you require for development/testing.
* Split the flow by sending the files to a network disk, where PitStop Server processes them and puts the output back on the network disk.
* Use a second PitStop Server license.
Contact your reseller, you can get also a Pitstop Server developer license.
Best regards,
Thomas
						Best regards,
Thomas
Thanks for the information Thomas.
I will look in to that.
