[Solved] Parsing data from filename separated by a character
Post by gabrielp »
Is there an easy way to pull values from the jobNameProper with separators in this format?
Essentially I need a way to capture the first, second, third, and fourth value separated by an underscore.
Re: Parsing data from filename separated by a character
You'll probably need a regular expression; I don't think the string manipulation for variables is strong enough.
Do you have the scripting module? If so, you can use this:
var theRegex = /(.*)_(.*)_(.*)_(.*)_.*/;
theRegex.search( job.getNameProper() );
var theCompleteMatch = theRegex.cap(0);
var thePlateID = theRegex.cap(1);
Post by gabrielp »
Thanks man. Exactly what I was looking for. I have an e-book on regex I have had for a while now. Maybe it's time to finally read it. 8-)
