Switch Client
				arothenberger
Switch Client
I need to be able to remove the Switch Unique ID before the PDF enters the checkpoint for Switch Client. If I am having two files with the same name submitted, you can see both files due to the unique ID. I want to remove the ID so the files overwrite themselves. Any ideas?
						Re: Switch Client
If you do that, you're going to lose all metadata. Is that OK?
							Free Switch scripts:  open-automation @ GitHub
				arothenberger
Re: Switch Client
Yes that will be fine. I am not pushing metadata after the Switch Check Point.
Thanks,
Adam
						Thanks,
Adam
 - TOP CONTRIBUTOR
Re: Switch Client
Did my suggestion of putting 2 folders before SwitchClient, the first set to not retain Switch filename prefix and overwrite duplicates, not work?
