leading and trailing spaces: trim
ArielRauch
Post by ArielRauch »
I somehow forgot how to trim a string.
str.trim() does not work.
Thank you in advanced,
Ariel
Re: leading and trailing spaces: trim
No trim function in Switch Javascript Object Model but it's pretty easy to get this result with a replace call:
var str = "      foo        ";
">"+str.replace(/(^[\s\uFEFF\xA0]+|[\s\uFEFF\xA0]+$)/g, "" )+"<" //>foo<
HTH
Loic
Post by gabrielp »
loicaigon wrote:No trim function in Switch Javascript Object Model but it's pretty easy to get this result with a replace call:
Thanks for sharing this. That is very helpful.
ArielRauch
I agree with Gabriel - very helpful.
Thank you very much
Ariel
My pleasure. Be aware though that it will only remove trailing and leading "spaces". Something like "hey you" won't be considered with previous regular expression but I was sticking to the idea of trimming the string.
For the ones looking for a more global replacement like " he llo " to "hello", you may prefer to use :
str.replace (/[\s\uFEFF\xA0]+/g, "")
andrea mahoney
Post by andrea mahoney »
You can use a Switch Variable to do this with norm or trim from the Variable options:
job.getVariableAsString("[Job.NameProper:Space=\"norm\"]");
